USA data
Bilt4spd1964
Hi , I have the USA data plan but it does not work when I’m in the USA?
@BKNS27 wrote:
@Bilt4spd1964
Also manually connect to the AT&T or T-Mobile network and enable VoLTE on your phone.
VoLTE settings are unrelated to the ability or inability to use data.
@Bilt4spd1964
hairbag1
@Bilt4spd1964
ensure that you have Data Roaming enabled in the cellphone settings.
