2 hours ago
I have this plan:
The overview and the T&Cs seem to imply different things with regards to USA.
So when I go to the USA, does this mean:
1. I have my 65GB of data
2. I will receive phone calls made to my number from Canada
3. I will receive phone calls made to my number from the USA
4. I can call to Canada
5. I can call to USA
and
6. Do I need to buy the 15 day talk/text/data roaming plan?
Thanks!
Alan
51m ago
The answer is yes to questions 1 to 5 and no to question 6 (you don’t need to purchase US roaming add-on).
But you will need to keep your phone on roaming. You might need to manually connect to AT&T or T-Mobile and enable VoLTE for calling.
2 hours ago - last edited 2 hours ago
This plan is fully functional in both countries and between both countries, no add-ons needed.
Just make sure your phone has data roaming and VoLTE enabled while in the US.
