USA Roaming
PatG2
I'm in Alaska. I have the usa.canada.Mexico plan. I am able to text, but phone calls 'end' immediately. Is there a setting that I'm missing?
This also happened a few months ago when I was in Arizona.
DennyCrane
Sounds like your phone isn't VoLTE compatible, and because the US shut their 3G networks down you won't be able to make phone calls in the US until you upgrade your phone.
Text and data are not impacted by VoLTE.
https://www.publicmobile.ca/en/on/get-help/articles/volte
hi @PatG2
can you confirm what network you are connected to?
Also, make sure Roaming Mobile data is on
@PatG2
You will need to switch to VoLTE (voice over LTE) since 3G is no longer available in the USA.
Also, what is the make and model of your phone? It needs to be on the whitelist of phones to work in the USA.
Here is more information:
https://www.publicmobile.ca/en/on/get-help/articles/volte?_gl=1*1qks5fo*_gcl_aw*R0NMLjE3MzA4MTg5ODgu...
slusagm
@PatG2
in Alaska, you can only connect to AT&T, are you doing that? and mobile data works?
first, what phone do you have?  but if you can make calls, and just got disconnected immeidately, I don't think it is a problem with VoLTE, but a problem with coverage
but if you need calls now and mobile data works, download VoIP app TextNow and use the app to make calls
