US talk and text add on
catman2
Does the add-on take into affect the moment you redeem it? Or is there a waiting period?
dust2dust
I know you've chosen a solution but your choice of words makes me ask...did you "buy" the add-on using points? ie. redeem? I seem to think there's a delay in the points redemption but I'm not sure.
Using money to buy the add-ons is immediate.
hairbag1
It's activated as soon as you "buy" it and expires exactly 240 hours after.
@catman2 @Takes effect as soon as it’s purchased
