US roaming
omusat
Hi,
I payed for the 10-day US roaming (talk and text) and my phone us still unable to call or text. How do I fix this problem? I bought the same service last month, and it worked fine.
Thank you
 @Jb456 : It's not for me to approve anything. It was just an fyi. 🙂
Jb456
@Anonymous
Do you approve? 🙂
@Anonymous lol yes I know. Been lazy to make a new one. Since you pointed it out I guess I'll have to now haha
hairbag1
@omusat wrote:
Hi,
Thank you
Assuming you've added the add-ons correctly, they only work whilst you're in US.
If you are there, try turning Airplane mode on / off.
As suggested, manually select either T-mobile or AT&T, whichever works best for you.
Wear your mask !!  😷
 @omusat : You'll need to contact the moderators. There seems to be a rash of these going on recently.
 @Jb456 : after all this time, I just noticed your image shows the old question mark. fyi
Jb456
@omusat
Have to tried to manually switch networks from ATT to T-Mobile or vice versa?
If nothing is working and manually switching does not work. Contact moderators to investigate..
Or private message them at Link below.
In interim. You can download the TEXTNOW app. You get a Canadian number in your area that will allow you to call and text Canada and USA numbers for free over wifi or data from anywhere in the world.
