09-06-2019 06:12 AM - edited 01-05-2022 06:53 AM
Hi,
I have $15/month plan,(100mins outcoming call canada-widely),if i buy $8 US roaming talk only add on,can i make unlimited call to US and canadian numbers in US or have touse my plan mins(100 mins)? and i have to make my cellphone setting--data roaming on?
if i buy $15 US roaming data add on, i have to setup my phone APN settings?
thanks
10-13-2019 08:01 PM
Perfect, short and sweet, thank you
@Jb456 wrote:It will not use your 100 minutes..it will allow you unlimited talk for 10 days while in USA.
IMPORTANT do not buy add on until you're going. As once you buy add-on the clock starts.
Yes cell data roaming needs to be turned on.
You should not have to change any APN settings..
You may however have to manually select a Mobile network.
First select ATT and if that don't work try Tmobile
09-06-2019 08:18 AM
Thanks, I will try.
09-06-2019 06:43 AM
You can make and receive calls to both Canada & the US.
All U.S. Roaming Add-Ons will last 10 days. This 10-day period begins when you pay for the Add-On and ends 10 days later at 11:59PM ET. You need to enable roaming. US roaming does not use your regular minutes in your plan.
09-06-2019 06:20 AM
See this link for a guide how to purchase add ons
https://productioncommunity.publicmobile.ca/t5/Plans-Add-Ons/HOWTO-Purchasing-Add-ons/m-p/198974
09-06-2019 06:18 AM - edited 09-06-2019 06:25 AM
