US roaming
Moniquec00
I purchased the add-ons for US roaming and thought I needed both but now it looks like the data included text. Can I get a refund for the over payment?
Thanks!
1 REPLY 1
@Moniquec00
data roaming itself does not include Text, SMS Text.  However, if you only use iMessage and NOT SMS , then yes, you don't need roaming Talk/Text
So, which package you got? Roaming Data/Talk/Text Bundle?
if you got it wrong, while PM support is a prepaid provider and usually do not provide refund, they might be able to help to reverse the transaction and you can rebuy  if it was an honest mistake.  Message them and check with them:
