04-06-2018 01:56 AM - edited 01-04-2022 04:02 PM
04-06-2018 09:19 AM
@Wchian wrote:I recall being connected to t-mobile but not sure about at&t.
Yes, roaming is on and rebooting didn't work. My friends have service on their phones and one of them is on public mobile as well.
Try going into your settings and manually selecting the same network that your friend has connected on
04-06-2018 09:15 AM
Try swapping SIMs with your PM friend to see if it's a phone problem or an account problem.
04-06-2018 08:27 AM
04-06-2018 02:08 AM
Are you on AT&T or T-Mobile's network? Check in network settings. Is your roaming option enabled? Also try rebooting your phone.
If you need to contact PM Customer Support Agent, Start a Chat to Create a Ticket OR visit the Get Help page.
