US roaming limit
rurzarekne647
I have the Canada US Mex 0pan.  I am going US today for 2 weeks. Is there any limit to how much data I can use in US?
8 REPLIES 8
rurzarekne647
thanks all. I think I have the answer for everything I am looking for
Chalupa_Batman
The one factor that hasn't been mentioned is, what phone are you using while in the US? Several people sadly have the Canada US plans with phones that don't work in the US. Before you go down, check here to make sure it will work.
https://www.publicmobile.ca/en/get-help/articles/volte
"Enter your IMEI number" is where you want to enter it.
EDIT: Side note not also mentioned, make sure when you connect to the US providers, turn on Data Roaming.
yes, both will work
After you connected to the US data, you can use data , text and voice like you are in Canada
rurzarekne647
thanks again.  And I can receive 2FA text and I can call back Canada?
Remember you need to turn in Roaming data in your phone
When you are in US , the phone should connect to T-MOBILE or At&t or Verizon. If connection no working well, manually choose each of them and test
Yummy
Data limit will depend on your Plan. If plan has 10GB then your limit in any of those 3 countries is 10GB. After using all 10GB you will not have access to Internet unless you have some kind of old plan allowing you access with very slow speed.
rurzarekne647
thanks to the quick reply.
anything else I need to know to use the service in US?
slusagm
No particular limit, just the hard limit to your own plan
