10-21-2021 12:35 AM - edited 01-06-2022 03:50 AM
I am feeling so angry I am in the US and have purchase 3G of data and it is not working at all. My phone won't load and I can't use it when I am out. I did it last month and it was fine but since we arrived in Florida nope. It has been a waste of money and of course with public there is no one to talk to. Any suggestions or answers?
10-21-2021 12:56 PM
sign in to Self-Serve, to review your account, if you found at Available Funds: $$
Try To Purchase Add-Ons Using Your Self-Serve Account
To purchase Add-Ons using your Self-Serve account, follow these steps:
after you Add-on you have to do Rebooting your phone
what is mean for Rebooting the phone means to turn off your phone and turn it back on again.
Overview Of Add-Ons visit Here link.
also you try manually selecting network,
and do Rebooting your phone
This is quick and simple.
10-21-2021 05:16 AM
@traceytwa did you try to connect both T-Mobile and AT&T? Try to connect to both of them and see which one get you better signal
10-21-2021 04:17 AM
Log into your account and check your balance. Do you see $60? $40? $20? Or $0?
If you have purchased the wrong add ons contact customer support and explain your mistake and ask for a credit. You can also have them add the correct US roaming add on. It will expire 240 hours later.
You will have to wait a minimum 24 hours after expiry to repurchase or contact customer support to repurchase it within that 24 hour one period as only 1 US roaming add on of the same kind can be purchased at any one time.
10-21-2021 12:57 AM
Can you show a screen shot of your overview page? That way we know what you purchased else all you will get is conjecture and speculation.
Us roaming plans are valid only for 10 days then need to be renewed typically one day after expirery
10-21-2021 12:52 AM - edited 10-21-2021 12:53 AM
@traceytwa : So you would be familiar with the two steps to buy an add-on.
Did you turn on data roaming? Did you turn on your data? Did your data previously work in Canada? Do you have any signal? Can you manually scan for and find and connect to either AT&T or T-Mobile.
Edit: And you bought only 1 roaming bucket of data? And you bought the roaming data not the in-Canada data?
