03-04-2018 04:32 PM - edited 01-05-2022 04:19 AM
Hi Community,
can someone please, advise if Hawaii is covered if I buy 10 days US roaminmg add-on?
Thank you.
Service
03-04-2018 08:27 PM
Thank you!
03-04-2018 08:11 PM
@sleptsovsn I used it last May in Waikiki and Honolulu with no issue. Enjoy your trip!
03-04-2018 05:03 PM
Thank you!
03-04-2018 04:42 PM - edited 03-04-2018 04:43 PM
@sleptsovsnwrote:Hi Community,
Thank you.
@sleptsovsn Yes it is covered according to this PM post in 2016 introducing the roaming add-on
"Your U.S. coverage will include all 50 states, plus Puerto Rico and the US Virgin Islands. So, whether you are travelling to the snow-capped mountains in Alaska or to Hawaii’s sunny beaches, we will have you covered. For more details, check out our coverage map here "
https://productioncommunity.publicmobile.ca/t5/Announcements/U-S-Roaming-has-arrived/td-p/94947
