3 weeks ago
I wish I could phone a support line so I could scream and yell. More than once I’ve purchased a US roaming add on only to find that it doesn’t work when I arrive in the US. I then spend hours trying everything to get it to work.
For this trip I purchased US talk/text//3gb data for $30 and nothing works.
Anyone have any suggestions?
3 weeks ago - last edited 3 weeks ago
Probably this is the main reason why PM is an online service so members can’t yell and scream at them. 😉
You just need to change the settings on your phone to connect.
3 weeks ago
I could definitely understand your frustrations. However, if there was a phone services, screaming and yelling would not get you anywhere. That sounds like a two year old with a tantrum. As a customer service agent I would disconnect the call.
But wishing you the best with the suggestions provided.
3 weeks ago
AS per many, many posts US add-on and even Plan US/Can are hit and miss.
Connect manually to AT&T and T-mobile, activate roaming. Nothing else yo can do...
3 weeks ago
make sure Data Roaming is enabled. Set network to T-Mobile or AT&T. Make sure to use 4G..NOT 5G. You should have texting ok though.
