US plan
Bud52
I have a us/ Canada plan. I purchased in Canada. I'm on the at&t network. I am able to text but can't receive phone calls. It worked great before today when I received a call from Canada. I've reset the phone by shutting it off very many times now & put on airplane mode off & on. Please help I need a reset. Bud
Bud52
I did change to T-Mobile and worked fine after that
HI @Bud52
other than T-Mobile, try also AT&T and Verizon.
Each network has it strong and weak location, one one is the best.  So, try them all and change it manually if necessary
DarkKnight_1000
Try manually selecting a network. I’ve found that T-Mobile works the best.
hairbag1
@Bud52
you must have a VoLTE enabled cellphone that is recognised by Public Mobile in order for talk to work in US. Here's some further explanation with a devise checker at the bottom of the page...
https://www.publicmobile.ca/en/get-help/articles/volte
