US data roaming for 10 days
mackie101
Hello ..Added the wrong data add on to my account. How do I get a hold of an actual person to help with this?
dna2016
@mackie101  unfortunately there isn't a way to get to an actual person (i.e. by phone), you will need to message the MODS directly and wait for them to respond, which can take even up to 5 days depending how busy they are.  I suggest going back to your My Account and adding the correct add-on that you wanted so that you're not waiting for a long time without the feature you wanted originally.  I'm sure the MODS will make the appropriate adjustments once they a hold of you.
mimmo
@mackie101  What addon did you buy and what addon did you want?
Typical reply time once contacted is between  2-48 hours.
If urgent buy the addon you need. Hopefully you will get a credit on your account for the first one. But there are no guarantees.
missorange
This is prepaid service, normally no refund, but you still can have a try by sending a message to MOD team.
duffer900
If you are having issues with your account it is recommended that you click here and contact the Public Mobile Team.
kelvarnsen
Click the little envelope on the top right of the screen. Send a private message to the Moderator_team. They may be able to help.
