US add on
David1991
Hello,
I am logged into my account and trying to figure out how to sign up for a US add on to my Canadian phone plan. I see where it talks about the add ons but don’t see where to purchase them. I also can’t see where it shows my current phone plan. Thank you
@David1991
Once you login to your account, go to Shop Add-ons>drop-down menu for Bundles or Data. Choose which add-on you wish then tap on + to 1...it is that simple.
@David1991  Here’s how to see current plan
simply try refreshing the page to check data plan / mins / add ons
and you will see the add on  on the subscription add on page
@David1991
After you login My Account, click Add-ons on the top right or use this direct link
https://myaccount.publicmobile.ca/account/manage/shop/addons
You should see the US roaming add-ons there
