US Roaming
Skookumchuk
I purchased additional talk/text roaming after my first purchase expired. The second purchase does not appear to have been added/activators as I cannot call or text. Simon is not responding with a follow up chat. Help!!!
1 REPLY 1
@Skookumchuk   did you re-buy the same addon?  did you wait 24 hours after the first one expired before buying the same one?
Yes, it is a bit trouble with re-purchase of the same add-on.  You might want to open ticket with PM Support and have them to check
1. If you have access to My account: At https://publicmobile.ca/chatbot.
2. If you don't have access to My Account or have trouble with Chatbot: Private message CS Agent at:
