06-29-2022 12:31 PM
We are going to the US and I purchased the add on, US roaming talk & text plus 250 data. My question is, can’t I just use my data that’s already on my plan?
Add-Ons
06-29-2022 11:49 PM
How long are you staying in the US?
It might be cheaper to purchase a local SIM if you are staying long term.
PM Roaming allows you to connect to AT&T or T-Mobile cell towers so it is not covered under your PM plan.
Remember when purchasing Roaming data, it is a 2 step process...put the funds into your account then make your Roaming purchase.
06-29-2022 12:42 PM
@dani99 wrote:Okay, thank you! How do I get more data then 250? Do I add it on or is that only going to add it on to my Canadian data?
do you need voice and text?
you can buy Data only roaming
or you can buy Bundle first, once you used up the data, buy the Data add-on when you need more
Here are the choice you have that have data there
Bundle - US Roaming - Talk Text (10-day) - $15.00 (10 Reward points)
Bundle - US Roaming - Talk Text 250 Data (10-day) - $20.00 (15 Reward points)
Data - US Roaming - 1 GB Data (10-day) - $20.00 (15 Reward points)
Data - US Roaming - 250 MB Data (10-day) - $10.00 (5 Reward points)
Data - US Roaming - 500 MB Data (10-day) - $15.00 (10 Reward points)
06-29-2022 12:41 PM - edited 06-29-2022 12:44 PM
@dani99 There is a 1gig roaming add on that you can get instead of the other personality I don’t believe the talk is working well down there because the 3g networks are shutting down
06-29-2022 12:36 PM
06-29-2022 12:32 PM - edited 06-29-2022 12:33 PM
@dani99 Hi no that is for Canada you do need a roaming add on remember your add on starts immediately
