US Roaming
Paul49Adelaides
I have a Canada, US, Mexico plan , and I am planning a holiday to Florida in a couple of weeks , what do I need to do to be able to use my phone for calls and texting , I will use data when I have wifi
Paul49Adelaides
Thank you , it is most helpful
What phone you have now?
Make sure you enable Mobile Data Roaming when you are in US and make sure the phone connects to one of T-Mobile/ AT&T / Verizon
Socrates8567
First, go to this link and confirm phone will work fully with the pm network.
https://www.publicmobile.ca/en/get-help/articles/volte
when you're down there, make sure data roaming is turned on. if you have problems, you can go into carrier settings and turn off automatic and choose a network there.
Just know, when you get to the US you will get a text saying you need to pay for service. ignore it as you have the CA US MX plan.
