US Roaming not working
Malleyp
I paid for 15 days US roaming. The money has come out of my bank account. I have 3 days left. I cannot make a phone call in the US. I get a message saying I did not buy the add-on. But I did.
Are you using an iphone? iphone allows you to do instant messaging that looks a lot like texting. Are your texts green or blue bubbles? Are you still able to text to an Android phone? Are you able to use cell data (not wifi)?
Adding - does "texting" only work when on wifi?
Malleyp
Yes
@dust2dust wrote:
What's this?..#4 now? Sheesh. This is a problem. Only support can fix that for you. Figures Public would screw up yet another thing.
At least 4 @dust2dust 🙄
@Malleyp If your 15 days are not up and you are getting that message submit a ticket to CSA and inquire about why this is, and get them to fix this.
­­­Public Mobile Representatives customer support­­­ agents (CSA) can be contacted by either two methods, found here:
darlicious
@Malleyp
Can you text?
hi @Malleyp so, the first 12 days worked?
you got the bundle with voice?
try make calls in different part of the city.  Roaming Talk needs 2G on T-Mobile, which is not very reliable
dust2dust
