$25 referral ($5 for 5 months)
Mindy208
About $25 referral ($5 for 5 months). If I have two friends A and B. I shared my unique code to A. I and A both get once $25 referral ($5 for 5 months). How about B friend? He also used my unique code and does he get regular 10 dollar credit or $25 referral ($5 for 5 months) ?
I mean I don't know how many referees do the referrer could referral?
Edit : I know I ONLY get once $25 referral ($5 for 5 months). How about my second friend, does he get regular 10 or $25 referral ($5 for 5 months)? I am NOT talking about me, I am talking about him and how much he get if he uses my unique code.
Thanks for your information
11 REPLIES 11
@Huggin
There's no one time per year restriction. It's a limit of one set of credits per promotional period, although somwtimes, the offers could be targetted based on any number og criteria that Public Mobile might set.
Huggin
Customer support agent told me the $25 is a very special promotion, you can only get one time in the same year.
Mindy208
Just clarity to you. CS_Agent reply me , For B friend, he can still get $25 referral ($5 for 5 months) if A and B both uses my unique code. I ONLY get $25 referral ($5 for 5 months) ONCE credit. But they are new customers before September 2, they all get $25 referral ($5 for 5 months).
Mindy208
Just want to clarity. CS_Agent reply me , For B friend, he can still get $25 referral ($5 for 5 months) if A and B both uses my unique code. I ONLY get $25 referral ($5 for 5 months) ONCE credit. But they are new customers before September 2, they all get $25 referral ($5 for 5 months).
@NDesai wrote:
Your friend B will get it though.
@NDesai- Are you sure about this? I suppose it's somewhat reasonable to assume. But are you sure?
@RossN wrote:
@NDesai hi I believe you are right about most of it but @Mindy208 has been here since 2020 so wouldnt she get dollars instead of points?
Yes, you are right. It all depends on which rewards program they are on. $1 or 1 point technically means the same.
NDesai
@Mindy208 Both of you will get $5 off for 5 months (30 days). You will get 1 point a month in addition as long as your friend stays with PM. If you refer another friend before Sep 2nd, the $5 off for 5 month promotion will not apply to you. Your friend B will get it though. You will receive another 1 point. So in total you will get $5 off for 5 months + 2 points for referring 2 friends. You will get to keep the 2 points per month as long as they stay on PM.
MrSpock
@Mindy208 hi only your first referal will get the 25 dollars 5 x 5 , if you refer a second person you will get 1 dollar per cycle  and they will get 10 dollars
CountyDownIeUk
For the $25 RAF you can only get one per account. If you have another account you “might” receive the $25. But I still think the offer was targeted to specific referrers.
@J_PM
Timer
@Mindy208
for A > will be starting from August 15th, until last day Sept. 2nd. for just one customer you and your friend will both credit.$25 for 5 month x $5.
Edit: for B >  your new friend will received 10 points = $10..you getting credit $1.if you are on old rewards
but if you have other line then use code to give your friend B can getting that credit.$25 for 5 month,
your friend stays with PM then you getting after 5 month for $1 for each friend you bring.
