US Roaming is not working
07-29-2017 11:12 AM - edited 01-05-2022 02:32 AM
Service
07-29-2017 11:40 AM
@osama49, do you have an amount showing in "Available Funds" If there is money there "re-purchase" the addon and it will take the money from there
07-29-2017 11:39 AM
Yes, I selected AT and T and later T mobile and both didn't work, my phone is unlocked
07-29-2017 11:36 AM
07-29-2017 11:14 AM - edited 07-29-2017 11:15 AM
did you follow the two step process for purchasing an add on/ do you see the add on in the "my plan and add ons" section of self-serve
If you have seen the add on in your self-serve, have you tried manually selecting the network? Also is your phone unlocked?
