US Roaming Issue
Gerry_P
Talk/Text/Data package was purchased today. I'm in Chicago and connected to T-Mobile. Talk and text are working but data is not. Chrome browser tells me I'm offline.
Is it possible I have to reset the APN. My current APN is Telus:
sp.telus.com
Proxy - not set
Port - not set
@hairbag1 wrote:
@Gerry_P
make sure Roaming is enabaled in your phones settings.
In this situation, changes to that setting wouldn't have fixed this issue as from thef first post, the APN was set incorrectly.
@Gerry_P wrote:
Yes, roaming was enabled as well as VoLTE. I figured out the problem though, it was the APN. I reset the APN to the Public Mobile settings from Telus and data is working now.
For future reference for anyone who might read this thead, Public Mobile's APN is sp.mb.com.
Gerry_P
hairbag1
@Gerry_P
will13am
@Gerry_P , check that roaming data is turned on in the settings.  The APN should be the same Public Mobile APN that you used while in Canada.
