01-16-2023 04:31 PM
I have 3 days left on my US Roaming, but can not make a call, send or receive a text. I have turned off and on my phone, and am connected to T-mobile here in Florida.
We have been using the same package for the last 4-5 years as seasonal residents in Florida and it has always worked good.
Hope someone can help me.
01-17-2023 05:33 AM - edited 01-17-2023 05:34 AM
In the US pm customers using roaming add ons or on the $60 Canada/US Roaming legacy plan can only use T-Mobile's 2G network for voice calls until telus implements VOLTE calling for pm customers. Being able to connect to their 2G network is location specific as Florida doesn't have great 2G network coverage compared to the rest of the eastern seaboard. You can check the linked cell mapper T-Mobile 2G coverage map in the update in the linked post below....
However you shouldn't have any issue with text messages as they use the 4G LTE network and incoming pm texts can be recieved without any US Roaming add on at all. Did the problem occur after your last renewal? If so it could be a provisioning issue with your Sim card. Contact customer support and ask them to reset your account and reprovision your Sim card to your account. If that fixes your texting (and the calling as well if that has only been problem alongside the texting issue) then I would also ask for a credit for your inability to use your roaming services.
There are links to contact customer support in the following thread's original post as well.....
01-16-2023 04:48 PM
Make sure you're viewing up to date information on the self-serve site.
Open an incognito tab before logging in to view the add-on details, and refresh the login screen when logged in to be certain.
01-16-2023 04:47 PM
@PerryGB was it working well the first 7 days?
US has shutdown 3G network ast year and hence your experience could be different. We got mixed reports about voice in Florida using TMobiles 2G network
Text should not be an issue but Voice could be a trouble
you see you now connected to TMobile?
do you have your Preferred network set to Automatic? you can try to set it to 2G to see if it connects and see if you can make calls that way
01-16-2023 04:33 PM
@PerryGB try restarting your phone, or perform a reset of the device's network settings.
Also, is your plan currently in ACTIVE status? You must have any public mobile plan in ACTIVE status to be able to use any type of addon services.
Check your My Account to be sure is says ACTIVE.
