US Roaming Add On Question
dipens
So if I and my wife (both with PM) buy the US Talk only add on,
1) Will we able to call each other?
2) Will I be able to make calls to Canada?
3) Will my long distance add on still work to call other countries?
Tried search the forums, but couldn't find something similar.
Thanks,
2 REPLIES 2
dipens
Okay awesome. Thanks so much.
ShawnC13
@dipens, Yes you will be able to call each other, yes you will be able to make calls to Canada.
I don't think you will be able to call other countries.  I think that addon is only available when you are on the PM network.
