Options
04-26-2017 11:23 AM - edited 01-04-2022 01:43 PM
Confused about this add-on.
Under the Plans Tab it is advertised as $20 but when you go to actually buy the addon is says $30. Whats the real cost?
thanks
M
Edit: NVM I figured it out
1 REPLY 1
Options
04-26-2017 12:52 PM
Hi @maninz!
Glad that you figured it out on your own.
For those wondering, the 1GB local data add-on costs $30.
When looking to purchase a US roaming add-on, just be sure to select the add-on that explicity says "US roaming".
