US ROAMING
Vixen
How does the US roaming add-on work?  If you're from Canada, and get the US roaming add on - can you talk and text to Canada from the US at no charge/unlimited?  Or it just allows you to talk and text within the US while you are there?
2 REPLIES 2
DDM69
The add on takes effect immediately.  It is meant to be used only while you are in the US and connected to a US network.
JRod
@Vixen
The US roaming add-on’s will allow you to use your phone as if you were home. So you can call Canadian and American numbers unlimited for the 15 days and use your data while you are in the US (if you also purchase the 3GB of data roaming).  You can purchase just talk and text, just data, or a combo with both.
Just make sure you have data roaming on and connect to either T-Mobile or AT&T. If one doesn’t work for you, manually connect to the other.
