10-28-2024 03:20 PM - last edited on 10-29-2024 12:04 AM by computergeek541
Hi, can anybody confirm that they have recently used their US data in New York City? I'll be travelling in the near future and want to make sure my data will work. I've noticed that I often lose coverage locally when I'm in a densely populated area, so going to the heart of NYC concerns me.
Thanks!
10-28-2024 04:07 PM
This is actually what I wanted hear,thanks!
10-28-2024 04:02 PM
i used in NYC earlier. Got connected automatically to T-Mobile and used it no problem
i briefly connected to the other 2 networks and both work
10-28-2024 03:40 PM
@JennLC Then you will be fine calls are the tricky part of roaming text and data are easy part especially with so much free wifi around
10-28-2024 03:39 PM
I'm not worried about voice calls, just concerned about data. So fingers crossed data will be no problem
10-28-2024 03:37 PM
Thanks for this info. I never knew about this white list. This is helpful!
10-28-2024 03:33 PM
@JennLC What phone do you have ? If it’s not on the voLTE whitelist , then you won’t have the best experience we can check for you or check here yourself . If it’s on the list you shouldn’t have any issues
VoLTE white list
10-28-2024 03:32 PM
hi @JennLC
data should have no problem
and what phone do you have? some phones not compatible with PM with VoLTE so voice calls might have problems on those phones
10-28-2024 03:28 PM
I'm new to public and haven't user my phone in the nyc yet, I was just hoping I could get some confirmation from users that their phones have worked in nyc.
10-28-2024 03:27 PM
hi @JennLC so, you had problems on NYC before? No problem for me and remember you can try connect to all 3 networks and test, T-Mobile, At&t and Verizon. And better to change network mode to 4G or LTE
10-28-2024 03:23 PM - edited 10-28-2024 03:23 PM
@JennLC If you have CAN/US plan or U.S. roaming add on it should be good to go . Just put data roaming on in phone settings and set phone to 4G/LTE not 5G and make sure your connected to T mobile AT&T or Verizon , also make sure your phone is on the PM volLTE whitelist if it’s not making calls will be a issue
VoLTE white list
