US Call
sudhirmool123
when i dial 1-347-514-XXXX us number it says number busy try again all the time. I have US plan why i
7 REPLIES 7
hi @sudhirmool123
it actually works using TextNow.  I think it is time for you to remove the phone number or your friends will keep getting calls this afternoon
Try my suggest above (reboot, reset network settings) or try using the app to make call if you need to call your friend quick
@sudhirmool123 wrote:
That's what i get, but it works from telus landline phone.
Their provider may think that the number that's calling is spam. Has that person tried calling you from that number on your PM phone?
hi @slusagm @sudhirmool123
I called too, it said the person is unavailable instead of not in service.
@sudhirmool123 , try making the call using other phone or use VoIP app TextNow, it can make free US calls
sudhirmool123
slusagm
what number is that?  i tried calling, it gives me the number is not in service.  That's why you are not able to call
and I was to ask you to remove the phone number , but since the number is not in service, it's ok, I guess
hi@sudhirmool123
reboot the phone, wait 5 mins and try again.  Also, try calling +1 ### ### ####
if still does not work, try Reset Network Settings
Chalupa_Batman
when i dial 1-347-514-7296 us number it says number busy try again all the time. I have US plan why i
Hello @sudhirmool123  Please remove the phone number if it's a personal friend or someone like that. These are not private forums.
