E sim
Mattn705
can someone please help me my account wont activate because the esim will not install proper..... After i choose my region and number it wont install e sim then sends me to look for help.. I typed im my imei number and said yes my phone is e sim compatible ... Can you please help
2 REPLIES 2
slusagm
so, did you get to step 6 during activation? or you are still in the earlier step?
check if the esim is install on the sim screen.  If you don't see it there, try to logout the PM app, reboot and log in again and see if the app will install the esim again
last, ask PM to help.  Since you cannot properly login, you won't be able to open the preferred Chatbot ticket.  So, you will need to message them here:
 hi @Mattn705
the esim probably is installed and just not configured properly
you might first make sure the old carrier sim is removed or disabled if it is an esim
And Go to Settings-> Cellular or sim manager and make sure the Public Mobile esim is there and enabled (or Turn on this line option is enabled) and set as Primary. Then Reset Network Settings.
In case you don't see a Publc Mobile esim there, check the Welcome email from PM and there is a QR code to scan and install the esim
If you still need further help,  ask support agent .  You can submit  ticket by direct message:
