US Add On...worth it?
Coaster
Hello,
I'm travelling from LA to Vancouver on the I-5.
I want to purchase the $15 Talk and Text plan.
I have 3G and I see some carriers are dropping 3G so, will I get any reception along the way?
I'm using iphone8 .
Thanxs in Advance
Coaster
Thanxs a ton you guyz, great info!
@Coaster
PM Roaming US Add-on was reported not so reliable. If you are still in LA, it is worth getting a Mint, Tello, Boost or TextNow SIM.
If it is short term, look at TextNow on T-Mobile network.
golfball
Until PM adds VoLTE support (which they've said they will be doing) the calling roaming add-ons will be unreliable.
Meow
Your success to connect to t-mobile and have any service in USA will  much depend on your luck.
Many people reported and complained US a--on did not work for them. Apparently data might work but then you have to use voip app for calls/sms.
Outdoorsman
@Coaster hi talk is not reliable and getting worse,personaly I would buy a US sim
