09-21-2019 09:50 AM - edited 01-05-2022 07:13 AM
Hi
Last month I switched to a $60 plan which has U.S data roaming. While I was able to use my data in the U.S. in the last cycle, it stopped working by the change of cycle. I can still call and text, and I see the 3G or LTE sign but there is no actual internet connectivity. This is super-inconvenient as I am traveling now. Any ideas?
09-21-2019 10:45 AM
As you wait for moderator response, a couple of other things to try:
Manually select the USA carrier, either T mobile or AT&T. Try both.
Toggle airplane mode on and then off.
Network reset
09-21-2019 10:19 AM
@mniknam One more thing to try while waiting is to make sure roaming and data are turned on within your phone settings. Also power down your phone remove the sim for 15 minutes and then re-insert the sim power up your device and test to see if it has been resolved.
09-21-2019 10:14 AM
None of the apps are connected and the counter has been reset as well. I just submitted a ticket.
Cheers
09-21-2019 09:58 AM
@mniknam wrote:Hi
@mniknam Check your selfserve account (overview page) to make sure that your US data counter was reset properly. If the data counter doesn't show and yur plan just went through a renewal then you need to submit a ticket.
What about accessing email or using another app other than internet? Does it work?
