04-16-2019 09:19 AM - edited 01-05-2022 07:13 AM
I signed up for public mobile yesterday. I decided to try and switch to my old phone number from Rogers which said was successful. I am now not able to receive incoming calls.. only texts and outgoing. Someone please help, this is frustrating as a new customer.
04-16-2019 08:57 PM
When I successfully ported my number with Public Mobile I received a text message letting me know it was ported. You won't be able to receive calls until then.
04-16-2019 02:36 PM
@Melissacorey66 wrote:I signed up for public mobile yesterday. I decided to try and switch to my old phone number from Rogers which said was successful. I am now not able to receive incoming calls.. only texts and outgoing. Someone please help, this is frustrating as a new customer.
This amount of wait time transfering from another wirleess carrier is not normal. It should have neen done within 2.5 hours. That on-website successful message does not mean that your number has been transfered. It only means that Public Mobile has assigned that phone number to your account.
Incoming calls will only work after the number has been transferred from Rogers. As others have stated, for now, keep using your Rogers service.
I would gather your Rogers account number and contact Public Mobile's moderators to get them submit another transfer request/correct the current transfer request. That can be done through this link: https://productioncommunity.publicmobile.ca/t5/notes/composepage/note-to-user-id/22437
04-16-2019 10:05 AM
Ok thank you!
04-16-2019 09:53 AM
04-16-2019 09:48 AM
04-16-2019 09:24 AM - edited 04-16-2019 09:25 AM
It could take a few hours for the port to be completed, try to restart your phone.
04-16-2019 09:23 AM - edited 04-16-2019 09:54 AM
@Melissacorey66: Porting is not immediate. What you are experiencing is normal. A port takes from 2 hours to 2 days to complete depending on when Rogers releases the number. Just be patient, in the meantime you can use your old SIM card to make/receive calls and once the phone stops working it means that the port completed and just start using your PM card at that point.
Hope this helps!
