05-18-2017 06:43 PM - edited 01-04-2022 01:48 PM
05-18-2017 07:50 PM
@buttonholes111 as @SD08 mentioned, it's a two-step process; however, if you see the add-on on your account, then you've successfully completed the second step already. So I don't think that's the issue.
Try a reboot as suggested, and if that doesn't fix it, go into your network settings on your phone and turn off automatic network selection. The phone will scan for some time (can take 60+ seconds) and then come back with a list of available networks. Choose either T-Mobile or AT&T and then test if your data is working. If that doesn't work, repeat the scan and try choosing the other of those two and see if that works. Some phones work fine on auto selection, while some seem to need manual network selection while roaming in the USA.
05-18-2017 07:25 PM - edited 05-18-2017 07:41 PM
Normally, buying an add-on is a two step process (first "purchase" merely adds funds, second purchase actually buys add-on with those funds). However, you say you see the add-on in your account already, so the next thing is...
Have you tried removing/reinserting SIM, then rebooting your phone?
If that doesn't work, then you should send a private message to a moderator for help with this. How to contact moderators:
http://productioncommunity.publicmobile.ca/t5/Knowledge-Base/Updated-Contacting-our-Community-Modera...
