08-21-2025 02:31 PM
I’m a new subscriber with a data package for U.S. and Mexico, on my first trip to U.S. data did not work. In my cellular settings on my IPhone 13, there is no option to roam? It just lists two lines, Primary and Secondary, both with my one phone number?
08-21-2025 05:13 PM - edited 08-21-2025 05:14 PM
It's because you have more than one SIM. The Settings app completely moves things around for dual SIM users.
You need to go to Settings > Cellular and then tap on your number and then the switch to enable data roaming will be somewhere on that screen. Here's an example image I found.
08-21-2025 03:42 PM
When I go into Settings , Cellular, Cellular Data, this option is not there, it only lists Primary Number( which is ticked) and Secondary Number
08-21-2025 03:29 PM
08-21-2025 03:28 PM
On an iPhone, go to Settings > Cellular > Cellular Data Options > Data Roaming (turn it on).
Make sure your network selection is set to Automatic.
08-21-2025 02:56 PM
@Neen1 to turn roaming on, you go to Settings Cellaulur, >Cellaulur Data > tap on.
Also, located the Vouce and Data Options and enable VoLTE if it's not already enabled.
Make sure that you have the latest IOS version.
Your phone number should be in Primary.
