Two same priced plans x2
For anyone considering the 65GB for $45 on the website on sign up
Be sure to immediately check your account for this exclusive offer same price with extra 10GB of data
75GB for $45 essentially the same plan same price for 10GB extra and make change for next renewal and not immediately
In our accounts it shows 20GB for $30 CAN /US plan and 15GB for $30 non CAN/US plan so choose wisely and pay close attention for the best value plan
15 REPLIES 15
@Hiltz  4G and 5G speeds on paper sounds like a lot up to 100mbs 4G plan and up to 250mbs 5G plan , but I reality you never get those top speeds and typically it’s not even noticeable diffence maybe half a second faster to load webpage on 5G in optimal conditions standing under the cell tower . So if it’s same amount for same amount of GB o would pay more for it I only lay more for more GB  infact I was in 60GB $34 5G plan and just switched to 20GB $30  CAN/US plan 4G plan because it’s harder to downgrade plan price and it’s better value I believe especially since the speed is almost the same only time 5G is much quicker I find is with Telus 5g+ speeds up 2GBps even then your lucky to get 700mbs you just never seem to get the top advertised speed carriers claim . But 4G is the exception to the rule where I find you can still get the top speed for whatever reason as most home internet is only 100mbs but many times it’s more like 70-80mbs
Hiltz
also, if your device is capable of 5g network, it's worth the extra 5$ for 5g 50 GB /month. if not 4g is a little cheaper. Even if your usually on wifi, it's always comforting to know i can contact someone thru fb messenger if cell towers are scarce. as well, gps and google maps are handy when no wifi available. even though i only usually use 5gb /month, i don't think a less gb option is available. unfortunately.
Shubh2023
I really get your point and I feel like it also matters about the consistency in speed, wherein 250Mbps is a good speed. About the speed, I agree with you but if the internet is consistent, then only it would be easier to complete it. I feel like 50 GB is good enough amount for me, considering I might not be willing to pay $50+
Shubh2023
Thank you very much for the feedback and yes, hundred would be too much for me, but it wouldn't be that much problem to completed everything, if the speed was higher then you can use up a lot of data in smaller period of time!
is your concern 100GB is too much data or you are not happy with "limited to 250Mbps" speeed?
yes, 100GB is a lot to use for any individual even you are out most the time.  I think it only make sense if you hotspot with 2 others or you really getting rid of home internet.  But worthy or not also depends on the price.  I think it was $50 before but now is $55 because it adds Mexico roaming into it
for 250Mbps , it is not a slow speed.  I don't see you can fully utilize the speed on a phone.  Even with 3 persons sharing hotspot, 250Mbps is decent
@Shubh2023i100GB is a lot of data and only the one selecting it knows if it’s worth it . I liken lots of data I just don’t like the price tags that comes with 100GB . So if you don’t need that much fat then no it’s not worth it in. My opinion. But again only the end user can make the call  on if it’s worth it or not
Shubh2023
I had 1 quick question related to plans having 100GB
Do you think it would be worth taking a plan, with 100GB, but you are limited to 250Mbps speed? I mean, thats good for people using gigs of data on the go + using as an hotospot. But, generally speaking, that would still be a lot of data XD
@beta578  Note it’s harder to down grade plan price these days too . So if the 20GB for $30 CAN /US plan available to you . It could be wise to make the plan switch if the 20GB is enough data for you because if they happen to come out with even cheaper plan like say 20GB for $25 it might be easier to get that offer being in $30 plan apposed  to $36 plan . So food for thought but at same time best to check your account everyday up until Black Friday for anything else that may change
@beta578 wrote:
Hmm I guess I’ll keep it as it is then I got the $36 50gb plan use it for 3 months and then see what they have by end of January thank you
HI @beta578
keep in eye with the boxing day deals , by then you might be able to use Change on Renewal and schedule a plan change end of Jan.  Hope the time works out so you can get the full 50% off and get a better deal after
beta578
@beta578  You most likely lose the 50% off , but you have to decide what’s best going forward after the 3 months for plan price and data value
@beta578 wrote:
If I change plans on next renewal will I still keep my 50% off the first 3 month promotion?
HI @beta578
pretty sure you won't get to keep the 50% off for 3 months.  For all those promotions, you need to stay with the same plan
slusagm
Thanks.  I have that $45 75GB too
beta578
thanks @Handy1 for the info
for those who current only lower priced plan, the $20 3GB is a great buy too.  Although you can save $1 for a $19 1GB plan, but paying the extra $1 for additional 2GB is a true bargain
