05-12-2019 11:03 PM - edited 01-05-2022 04:54 AM
Request to be ported over 2 days ago, only partially ported as I can only call out and text. Can't receive call. My number is still active on both my old sim with freedom and new sim with public. No help from Mod via private message submitted a day ago. I see all my activity on freedom is getting charge on both carrier (running out of text and minutes since I have to constantly test if portting is complete). Have to constantly switch between sims in case someone calls. Went to the store that ported me over and Public Mobile said it suspended my port partially for unknown reason. Resubmitted it but that was 10 hours ago. Already tried every trick mentioned in the forum, restating, lost/stolen reactivate trick. Since there is no live or semi responsive help, what to do. I get this is why the rate is cheap on public mobile but when there is a problem and can't use my phone properly for unknown amount of days with no update, what are my option? need my phone function for the work week. Have to stick to my old sim since I need to be able to receive calls. @CS_Agent
05-13-2019 08:42 AM
@computergeek541 wrote:
@geopublic wrote:@hk0808 Not much you can do at this point. That why it's best to select a temporary PM during activation. If they submitted the port 10 hours ago it should have been done by now. If it's not done by tomorrow morning I would send the moderators another message.
I'm not disagreeing with you about that being a good idea as there are some cases when the account doesn't get activated properly but Public Mobile somehow manages to still port the number in.
However, porting in after taking a temporary phone number during activation would not have prevented this situation. The second that @hk0808 submitted the port request, that number would have been immediately replaced and he/she would still be in the same sittuation. I would suggest to hk0808 that the Freedom Mobile account number be double checked and if that wasn't yet provided to the Public Mobile moderators, to do that.
Once a port is submitted on the Public Mobile side, I believe only the call display features will take on the ported number. However, that port is not completed on the Freedom Mobile end immediately. This is why customers are generally told to keep using the old service. Call display is superficial and shouldn't really affect much more than a display.
05-12-2019 11:25 PM - edited 05-12-2019 11:26 PM
05-12-2019 11:19 PM
@hk0808 wrote:Request to be ported over 2 days ago, only partially ported as I can only call out and text. Can't receive call. My number is still active on both my old sim with freedom and new sim with public. No help from Mod via private message submitted a day ago. I see all my activity on freedom is getting charge on both carrier (running out of text and minutes since I have to constantly test if portting is complete). Have to constantly switch between sims in case someone calls. Went to the store that ported me over and Public Mobile said it suspended my port partially for unknown reason. Resubmitted it but that was 10 hours ago. Already tried every trick mentioned in the forum, restating, lost/stolen reactivate trick. Since there is no live or semi responsive help, what to do. I get this is why the rate is cheap on public mobile but when there is a problem and can't use my phone properly for unknown amount of days with no update, what are my option? need my phone function for the work week. Have to stick to my old sim since I need to be able to receive calls. @CS_Agent
05-12-2019 11:10 PM
@hk0808 Unfortunately the moderators have been very busy lately. There usual response time is a few minutes to 2 days, hopefully they will respond to you soon. ![]()
Welcome to Public Mobile.
