Trying to return a phone
smrobertson
How do I return my newly purchased ‘used’ iPhone purchased online through Public Mobile?
I have followed the process online and am unable to ‘submit’ the online Ticket that is required to initiate this process. No amount of communication with the online chatbot has helped either. The ticket submission system is flawed it seems. I am now stuck with a phone that doesn’t charge or even turn on.
Amandalk745
If you log into your online self serve, at the top right hand side click the three lines drop down menu, at top of that you will see get help, click that, it will bring you to the community page, at the top once you have signed in there should be an envelope at the top right side click on that which should then bring you to your inbox where you will see a small white square with a pen like symbol, click that, that will bring you to a ticket under send to put cs_agent and your issue in subject and what you need to know in text box and they usually respond within 40 minutes.
dust2dust
Or the second - second method of using the pin option rather than the login option. After entering your community login, choose the pin option. It will need the name and number on the account and your 4 digit account pin. If you can login to your account and you forgot this pin then you can reset it in the account.
HALIMACS
@smrobertson
Before trying to submit a ticket, clear your system cache and cookies and open an incognito tab.
Then try again.
Have you tried using a different lightning charger to charge the iphone?  Give it a shot.. and let it sit on charge for 30 minutes to see if it does anything.
hairbag1
@smrobertson
before starting the process of returning the phone..make sure to log in to your account using incognito mode. Use Firefox web browser.
@smrobertson  - try the 2nd method to submit a ticket if SIMon Bot is giving you issues.
­­­Public Mobile Representatives customer support­­­ agents (CSA) can be contacted by either two methods, found here:
@smrobertson @You need to contact support
Getting help from agent
  • Get help with your account the easy way by starting a conversation with our virtual assistant, SIMon. It’ll take you to relevant help articles, or if it’s something more urgent, it can help you submit a ticket to our Agents. Click here to get
Or get help right here in the community
  • Alternatively, you can send a private message to our Agents by clicking here. You’ll need to be logged in to your Community account for the link to work
