Trying to port out
tesqie
I get a message to approve port out to fido. I send yes many times. 90 minutes later I get a message saying I didn't approve. I've done this many times.
10 REPLIES 10
tesqie
yeah... let me know if u figure it out.
ryanfung
Same I resubmitted using several methods - same issue.  Fido says that Telus/Public Mobiles porting system is down.
tesqie
I resubmitted 4 times
tesqie
yes I got rejection from fidos end several times
tesqie
no, I'm using sms
tesqie
yes it's active
ryanfung
I am having the exact same issue. it has been happening all night.   I request to port through the Fido Portal, get the text message, reply "Yes", and 90 mins later I get a text from Fido saying that they were not authorized.   Something wrong on Public Mobile side.  I ported another number the same time from Chatr and it worked.
It feels like Public Mobile is holding their users hostage, preventing them to leave.   Need someone at Public Mobile support to respond.  I cant even get someone on the support chat.
Are you using an iPhone and iMessage?  If that is the case, please make sure that the SMS option is enabled before replying to the next time that Public Mobile sends you the authorization text message.
@tesqie
Is your PM account Active? It needs to be active so you can port out.
Contact Fido to see what is the issue.
will13am
@tesqie , did you get the rejection on the Fido end?  Perhaps the wrong data was entered?  In any event the receiving carrier has to do all the heavy lifting.  So you will need to have Fido resubmit the number port.
