10-30-2021 05:46 PM - edited 01-06-2022 03:54 AM
I just ported over a number for my grandfather and set him up (24 hours ago) and incoming calls will not come through. I can call out on his phone, text and use data but when I call him or anyone else it goes straight to voicemail. He has a basic flip phone. I can be tech savvy so I've already checked all the settings and restarted the phone and updated his voicemail but nothing has worked. It has to be a PM issue. Can someone please help me.
Joining Public
10-30-2021 06:19 PM
Put the bell sim card back in the phone and see if it's working. If so then follow @t_p or @Anonymous instructions to call the telus porting department to reinitiate the port request and reply YES to the PAT (porting authorization text) within 90 minutes of recieving it.
Unless of course you cancelled the bell services before porting the number in then that's a whole other kettle of fish.
10-30-2021 06:08 PM
you miss a SMS message from your old carrier asking to confirm if you would like to port your number. Your reply should be: YES.
The confirmation message can take a few minutes to come in. You have 90 minutes from the time of request.
if you stuck with Transferring your old Phone Number,
Here’s how to contact Customer Support Agent by CS_Agent,
- or you can send a private message to Customer Support Agent by CS_Agent, by Click Here link.
- You’ll need to be logged in to your Community account for the link to work.
- please include in your message,
- your phone number,
- which carrier,
10-30-2021 06:05 PM
@kayla87 wrote:But the incoming calls still will not work.
So it looks like everything works but incoming calls.
Do they end up in a voicemail? Do you have another phone handy so you can call Your ported number and see what is happening? Call just gets dropped, goes into vmail, no ringing at all, etc.?
I guess you re not blocking numbers which try to call you?
10-30-2021 06:03 PM
@kayla87 : Shortly after doing all the activation and porting, the SIM (in a phone) would have received a text that required a response to confirm the transfer. If you did not do this step then the port will have failed and here you are. Use the number the earlier poster gave you to re-trigger the port and put the Bell SIM back in. My bet would be that that SIM still works.
This is how it works. You can do outbound but not inbound before the port completes.
10-30-2021 06:03 PM - edited 10-30-2021 06:04 PM
@kayla87 wrote:I have no way of finding out because the phone is transferred to public mobile now, so no the bell account no longer exists. I didnt reply to any text but I do recall seeing a text saying about how the $10 would be applied to the account.
If you haven't replied to the SMS, the port is incomplete. You need to call the number I sent, or contact PM customer service to restart the process.
10-30-2021 06:01 PM - edited 10-30-2021 06:02 PM
if you can't fix it you have to Contact Customer Support Agent by CS_Agent, and Explain your issue to they can solve your issue, they are nice service Team the will help you 100%.
Here’s How To Contact Customer Support Agent by CS_Agent, and Submit a Ticket
- Get help with your account the easy way by starting a conversation with our virtual assistant, SIMon. It’ll take you to relevant help articles, or if it’s something more urgent, it can help you submit a ticket to Customer Support Agent by CS_Agent,Click Here link,to get started.
- or you can send a private message to Customer Support Agent by CS_Agent, by Click Here link,
- your account number,
- your account 4 digit pin,
- your Email address,
- Customer Support Agent by CS_Agent, will Response to your inbox by private message
- During business hours, we strive to answer customer messages swiftly. You will often get an answer within an hour. During peak periods, you may need to wait up to 48 hours.Customer Support Agents are available:
- Monday to Sunday: 6 AM to 10 PM EST
Good Luck...
10-30-2021 06:00 PM
10-30-2021 05:59 PM - edited 10-30-2021 06:00 PM
you can try reseat the SIM card and Make sure your phone is off before removing your SIM card,
1. power off your device
2. take out the SIM card,
3. waiting a 1 minute,
4. put it back and power on,
5. toggling airplane mode off/on,
Go to Settings > General > Reset > Reset Network Settings.
This also resets Wi-Fi networks and passwords,
or visit Here link,
click Here link,
- Open the Settings app on your Android.
- Scroll to and tap either "General management" or "System," depending on what device you have.
- Tap either "Reset" or "Reset options."
- Tap the words "Reset network settings."
or visit Here link,
and go Changing APN Settings On Android device
click Here link,
Ensure you have the correct APN settings by visit Here link,
and do Rebooting your phone,
*what is mean for Rebooting the phone means to turn off your phone and turn it back on again.
can you try manually selecting network "3G ONLY" or WCDMA only,
for iPhone visit Here link
or Here link
for android visit Here link ,
This is quick and simple,
10-30-2021 05:57 PM
@kayla87 : But does your old service at Bell still work? Did you reply to the transfer confirmation text?
10-30-2021 05:56 PM
Ported from bell mobility... all seemed to go smoothly. Public mobile is up on the cell phone as the provider, that happened instantly. And i could make calls and text pretty much instantly. And when i make calls it uses minutes from the public mobile package so it seems that the porting process would be over. But the incoming calls still will not work.
10-30-2021 05:53 PM
@kayla87 : What kind of service did you port from? Landlines and voip services can take longer.
If you ported from a cell provider, did you confirm the transfer text? Does the old service still work?
10-30-2021 05:51 PM
Ok. But it's been 24 hours
10-30-2021 05:50 PM - edited 10-30-2021 08:02 PM
@kayla87 wrote:I just ported over a number for my grandfather and set him up (24 hours ago) and incoming calls will not come through. I can call out on his phone, text and use data but when I call him or anyone else it goes straight to voicemail. He has a basic flip phone. I can be tech savvy so I've already checked all the settings and restarted the phone and updated his voicemail but nothing has worked. It has to be a PM issue. Can someone please help me.
The porting is probably not completed yet. I'll send you a number to call and check the status. Check your inbox.
Edit: Did you reply Yes to a texto sent by the old carrier asking for confirmation of the transfer? You'll need to keep the old SIM in the phone to get that message.
Added reference if you want to learn more about the process:
