02-03-2021 04:02 PM - edited 01-05-2022 05:08 PM
I set up my account with Public Mobile and tried porting my number from Virgin. I now have an account with Public but my Virgin account is still active, and my number is still with Virgin. Unable to use Public as I have no phone number. ???
02-04-2021 06:57 PM - last edited on 02-04-2021 08:06 PM by Ioana_R
you can call the porting team to investigate the issue***
please click on the green chat bubble to the bottom right of your screen to speak with SIMon
type "missing reward"
(use the chat bubble options, then click "click here to submit a ticket!)
*login using your community account
make sure to check your inbox(top right corner envelope icon) periodically, for a response
edited by computergeek541: referral code removed
02-04-2021 01:38 AM
@noramax :Is your porting problem fixed? You should follow up with everyone here and let us know if you got everything fixed yet. If things fixed, you should choose one of the above posted replies as your accepted solution, to do so click the accepted solution button above the post that helped you most - this will mark this thread you created as solved, and will help others who have similar problems.
02-04-2021 01:00 AM - edited 02-04-2021 01:02 AM
@noramax wrote:I set up my account with Public Mobile and tried porting my number from Virgin. I now have an account with Public but my Virgin account is still active, and my number is still with Virgin. Unable to use Public as I have no phone number. ???
LIke others said, keep the Virgin sim in to wait for the text from them, but quickly check if your Public sim works. Outgoing calls, texts, and data should work.
02-03-2021 04:37 PM
Hello @noramax ,
Try one or more of the below:
*turn off your phone, leave off for at least 3 minutes, then reboot
*removing your SIM for a few minutes, then reinserting it
*go into airplane mode for a few minutes, then going back to regular mode
*reboot your phone again
If you just ported your phone number from another cell provider it could take a few hours to complete the port. Using the other cell provider's SIM you should be still receiving calls on it, until the port completes.
If you ported from a landline it could take up to 7 days to complete.
Make sure you do not cancel your previous provider's services until the port is complete.
02-03-2021 04:18 PM - last edited on 02-04-2021 08:07 PM by Ioana_R
Can you send texts or call out from your PM SIM card/phone?
Your port might be stuck. Call the Telus porting team **
Porting Your Number Into Public Mobile
If you are porting your number into Public Mobile, for additional security, your previous service provider may also send an SMS text to validate the transfer. Follow the instructions in the message within 90 minutes to approve the number transfer.
If you have missed the 90 minute window to respond, we will send you an SMS with instructions on how to re-initiate the transfer by calling our Porting team.
The SMS will read as follows:
Public Mobile Msg: The request to move your phone number to Public Mobile has timed out. Don't worry, you can easily re-initiate the transfer. Please call our Porting Team at 1-****to authorize your number transfer
Tips:
