05-28-2022 11:42 PM
iPhone 6s stolen early this week. Had Telus lock the number. Bought and activated PM SIM card and installed in iPhone 7 but no service. Do I need some sort of “manual override” to port my previous number over. How do I proceed? Thanks.
05-29-2022 12:41 AM
Is the number you want to port an original number when you got when starting with Telus?
05-29-2022 12:40 AM
As mentioned if your Telus account is not in good standing or suspended bc of the stolen phone that may be what is holding you up but since it is Telus they can probably work around that especially under the circumstances.
05-28-2022 11:56 PM
Thanks. Will start with that.
05-28-2022 11:52 PM - edited 05-28-2022 11:54 PM
All you need to do is login to your account and click on Change Plan>Lost/Stolen Phone to disable SIM then click on Change SIM card to keep your old number.
You might want to check if the iPhone 7 list Blacklisted:
05-28-2022 11:46 PM - edited 05-28-2022 11:46 PM
@Bart4 I believe you have requested porting when you activated. Usually only active account can be ported as you will need to reply a text on your old provider to approve the porting request. Luckily if you are porting from Telus, PM Support could assist this process. Please open a ticket with PM Support and explain what happen. They likely can help to complete the porting request
1. If you have access to My account: At https://publicmobile.ca/chatbot.
2. If you don't have access to My Account or have trouble with Chatbot: Private message CS Agent at:
**pleae note it is a bit late at night, they might not be able to help until tomorrow.
