Traveling
Sadfac3
Hello, can i use youre sims in other countries? Going for travel to sweden
funpig1
@Sadfac3 you cannot roam in Europe with PM. Check out Orange Travel esim or sim. I have used it in several European countries. I've not been to Sweden, but it is on the list of included countries. I prefer orange over Airalo, because orange provides a European telephone number which allows you to make regular calls and texts as well as limited calls and texts back to Canada. Have a good trip.
DDM69
Use Airalo. It works all over the world.
Dunkman
@Sadfac3
Except for the USA, Public mobile does not offer other international country roaming.
Your PM service will not work while traveling to Sweden.  Can purchase a domestic SIM card while traveling abroad.
