03-01-2023
12:23 PM
03-01-2023
12:25 PM
computergeek541
Is there an extra charge if you travel in Canada and use your phone for Canada only calling
Plans
03-01-2023 12:30 PM
self solution removed/solution re-assigned
03-01-2023 12:28 PM
Thanks for the clarification. Much appreciated
03-01-2023 12:25 PM
@sprky wrote:Is there an extra charge if you travel in Canada and use your phone for Canada only calling
No, there isn't. Canada-wide calling means that you can use in anywhere in Canada (that you have Public Mobile signal).
03-01-2023 12:25 PM
@sprky No
