Travel
antoniosales
Hi, I'd like to know if I can use my public mobile to call from US to Canada after I buy a Add-Ons.
I live in Canada and I will need to call to Canada when I'm in US.
Thanks.
Exactly. I like the way you think @Handy1 . The only the only thing is to change the plan before they go and to start on the next billing cycle. However if they start it earlier they'll lose what they've paid for.
With that being said, @antoniosales when is your billing cycle and when are you heading to the US and for how long.
The 24 hour wait is only if OP wanted to re buy the very same US  roaming add on . Otherwise they can purchase a different US roaming add on . But at that point it would make more sense to go with a CAN /US plan cheaper and more data much more
@antoniosales  Yes if you purchase a US roaming add on . Or choose a new CAN /US plan
