Transferring a prepaid number to Public Mobile?
jaxie3-
May I be able to transfer a prepaid Virgin Mobile prepaid phone number to Public Mobile?
smp99
Also, please make sure your phone is unlocked. But that can all be tested if you get a temp number first.
mimmo
@jaxie3-  being virgin prepaid pease port with a minimum 3- 4 days before your virgin renewal/expiry date. This is to ensure that should  you have a porting problem your virgin line does not become inactive since you need an active line to port.
Dunkman
@jaxie3-
Yes, you can transfer from Virgin Mobile prepaid account.
Some people recommend first getting a temporary new Public Mobile number first.  Try PM service for a while and if satisfied, then port your VM mobile number afterwards.
