4 hours ago - last edited 4 hours ago by computergeek541
Hello,
I am currently a Public Mobile customer and am looking to purchase an Esim for my new phone on the app, however it will not work, as there is a, "Before you procced," screen that will not let you press pay and install. Is there any other way I can buy an ESim for my new phone?
Thank you guys very much for your help and time, I greatly appreciate it! 🙂
2 hours ago
Yes. I remember hearing about this from another customer. Something about the pop up is blocking the purchase button. Only an Oracle here can clarify if if CS Agents are aware of the problem or if you should screenshot it and report it.
But @slusagm has the idea. Change the zoom feature on your phone and you should have access to the button.
3 hours ago
it's something blocking the button or it is below the screen area. Try to scroll up down on the screen or try to change the zoom level /resoluton
3 hours ago
Hey @Chalupa_Batman ,
The app lets me get that far, however a pop up appears that won’t let you click pay and install.
4 hours ago
Hey @audge1965
You need to login to PM app using the same email login as before and rebuy mew eSIM for free. Login to My Account, Click Account from the bottom, then click Purchase SIM Card and select eSIM.
Once it confirms your phone is eSIM compatible, click Pay $ and Install and follow the prompt to complete and purchase and install eSIM on your device.
4 hours ago
Hey,
Thanks for responding. I tried using my desktop to purchase an eSIM, however there doesn't appear to be an option to do so. The Public Mobile app simply does not work to buy an eSIM.
4 hours ago
@audge1965 wrote:I am currently a Public Mobile customer and am looking to purchase an Esim for my new phone on the app, however it will not work, as there is a, "Before you procced," screen that will not let you press pay and install. Is there any other way I can buy an ESim for my new phone?
Can you try using the web browser in incognito/privacy mdoe and try the self serve website again?
