08-21-2022 01:00 PM
I transferred my number two weeks ago from Lucky Mobile and still can’t send or receive texts or calls from certain people
08-21-2022 03:46 PM
Yes it took hours back and forth between the two carriers to get resolved
08-21-2022 03:23 PM
Hi @JRHArsenault how was this resolved?? after open ticket with CS Agent as advised hours ago??
08-21-2022 02:54 PM
Removed 8 messages all saying the same thing
08-21-2022 02:53 PM
Fixed it problem with the porting
08-21-2022 02:53 PM
08-21-2022 02:53 PM - edited 08-21-2022 09:09 PM
Response was the same as someone else from more than 1.5 hours earlier to open a ticket - solution corrected
08-21-2022 02:53 PM
Got it fixed!! Problem with the porting
08-21-2022 02:36 PM
08-21-2022 01:52 PM
She is my daughter
08-21-2022 01:48 PM
@JRHArsenault wrote:People can’t call her but she can call them does that make sense at all?
@JRHArsenault one second.. who is SHE? the one who just ported the numbe into PM? IF so, does that mean she is actually NOT receiving incoming calls or incoming text at all?
or you are one who ported, and she is the one you cannot call and text? and Just one person you cannot call and text?
08-21-2022 01:47 PM - edited 08-21-2022 01:49 PM
Do these calls go to her voicemail @JRHArsenault ?
If so, check that the caller(s) have not been accidentally blocked in the contact app.
Or, does she have her settings set up to only accept callers that exist in her calling app? If so, she can add these callers to her contact list, or turn that setting off completely.
EDIT, and to confirm...some incoming calls are coming to her phone right? Because if not, then this could be a stuck port; and if that is the case contact a CSA from softech's post above.
08-21-2022 01:45 PM
Tried all of that
08-21-2022 01:44 PM
08-21-2022 01:43 PM
@JRHArsenault - try performing a Reset of the device's Network Settings.
If using an iphone (new to you) that is new to your phone number, deregister the number on the iphone: https://selfsolve.apple.com/deregister-imessage/
Set up your phone number On your iPhone:
08-21-2022 01:39 PM
The porting process and text went off without a hitch then? You cna do some troubleshooting yourself and swap sims or call family or friends to see what comes up
08-21-2022 01:19 PM
So you are saying EVERYTHING works: in/out SMS, calls, Internet but cannot make connections with certain people?
08-21-2022 01:11 PM
You did type some other details but is your Lucky account still active? Did you confirm the transfer text? Are you using an iphone?
08-21-2022 01:04 PM
@JRHArsenault so, incoming calls and text are generally working?
for those who you cannot send or receive calls, any chance they are all from one particular provider? or they are random? And you do not just have problem with 1 particular one?
i think you tried rebooting your phone? did you try to manually key in the phone number with a 1 in front of the 10 digits? (Do you just use the contact or call /reply back on an old history) See if calls go through that way
Also, try to put your PM sim in another phone to test calling and testing those numbers and see if it works on another phone
if none of the suggestions help, open ticket with PM Support and see if they can reset your account to help
1. If you have access to My account: At https://publicmobile.ca/chatbot.
2. If you don't have access to My Account or have trouble with Chatbot: Private message CS Agent at:
