01-27-2026 10:47 AM
I have completed the transfer of phone number process last night and got to the stage that “I texted Yes to terminate my old phone number and transfer to Public Mobile”. I was asked to wait for the next step as it could take up to 5 hours. This morning I logged into my account and no information on what to do next. I tried to make a call and it’s not working. Can someone help me out with the next step? I have not inserted the new SIM card yet. Should I try it now?
01-27-2026 10:50 AM
Try inserting the new SIM into your phone, it may be fully ported to that SIM.
01-27-2026 10:49 AM
hi @JJL3
you removed your old carrier sim card? And make sure PM sim is enabled and set as Primary.
Then reboot phone and reset network settings and try
if PM is a physical sim, try it on another phone
but if you need PM support agent to help, you can submit ticket by direct message:
