01-27-2026 10:11 AM
Tried to port in my existing number from Fizz but it is saying Account Number is wrong. Did put in the padding zero in front of the 8 digits to make it 12. Need advice on how to fix it.
01-27-2026 10:55 AM
Could you please DM me the number? I'm running into the same issue
01-27-2026 10:36 AM
Hi, could you pm me that number as well. Having the exact same issue.
01-27-2026 10:34 AM
Hi,
I also have the same issue, can you please private message me as well. Thanks
01-27-2026 10:25 AM
Supposedly, need to add the zeros after the initial 8 digits.
I will private message you the Telus team porting number. That team should be able to complete the port.
