Transfer number from Public mobile to Chatr
bboy942
Hi, I would like to transfer my old number from Public Mobile to Chatr. Chatr called me and said it not possible because my Public Mobile number is not active. Since, I don't want to pay for a month to activate my Public Mobile number. There is any way to transfer my number?
Please help
Thanks
dLBallin
Your best bet is to re-activate your public mobile plan (preferrably with the cheapest option) and port out. If you set up auto-pay, the cheapest plan looks to be around $8. $8 to port your number over - doesn't seems so bad of a plan.
Sorry, you need to pay again. There isn't any way to transfer a phone number that isn't active.  How long has your Public Mobile number been inactive? If it has been inactive for more 90 days, you will not be able to reactivate it.
kav2001c
Old plans used to have 10 day cycles
Otherwise you need to pay for a 30 day plan in order to transfer number
NDesai
@bboy942 Best you can do is to change your plan to cheapest which is the $10 50 min talk and 50 texts. There is no way to activate for a day or two.
